Valves
summer
12-02-2001 13:25:30
we have an early 8n tractor and the exaust valve on the back cylinder stuck open. after running it for a while the valve the spring and the sleeve slid down. the c clip at the top of the spring came out and now the whole assembly is floating. there are pieces of metal inside the spring. I am wondering what the easiest way to fix this would be. If we could use a spring compressor to remove the spring and the sleeve around the valve from the bottom to inspect it and pollish the valve and sleeve to get it sliding freely. if anyone has any ideas it would be great to hear back
