Restoration & Repair Tips Board
flywheel bearing ferguson 20
peter brady
07-18-2003 11:21:09
Hi Lads and Lassies, I have a question about a Ferguson TEF 20 diesel tractor. How do I remove the bearing from the center of the flywheel. ( this is the bearing that the gearbox shaft fits into ). Do I need some kind of a pullers to do this?
Has anyone got a part number for this bearing please?
Any have a clutch trouble or pressure plate trouble. Clutch not disengaging?
Thanks Peter Brady
Ireland
[email protected]
Peter, U.K.
07-21-2003 01:56:36
 Re: flywheel bearing ferguson 20 in reply to peter brady, 07-18-2003 11:21:09
Peter,
E-mail me at [email protected] and I'll go through it with you.
Regards,
Peter.
TO-35Man
07-18-2003 17:16:22
I have a homemade slide hammer puller,snap on,napa and alot of tool makers have them...or you could try the old grease trick...pack the hole tightly with wheel bearing grease, then find a drift that fits the hole closely, tap with hammer and grease pushes it out...
hope this helps...
