Witch tractor do i have/ no spark
Ron
05-09-2003 22:33:38
it has front mount distribtor w/ grey tin & red motor.new plugs wires,rotor,cap & points. power to the coil,power to the points no spark thanks for any help Ron
tom in so il
05-10-2003 16:13:37
 Re: witch tractor do i have/ no spark in reply to Ron, 05-09-2003 22:33:38
If it was a 6 volt and converted over to a 12 volt it will have a ceramic piece attached to the coil. With the ignition, check for current to the coil, then to the ceramic piece. This converts the tractor to 12 volt and will go bad at times.
gatractorman
05-10-2003 03:06:46
Sounds like an 8N Ford, I would go over to the N- board and search the archives, spark and wiring problems have been answered there numerous times.
