Leaking Transmission Oil on MF TEA 20 (1950's)
Matthew Nowell
04-02-2003 13:02:16
Oil leaks from hole near flywheel housing at bottom when I put more than 12 Litres in the Transmission.It takes 22.8 Litres.Also the rear Tray drops slowley once you have engauged lift with the lever.
Any advice much appreciated.
(Anyone know where the tractors Serial Number would be?)
Many Thanks
Matt Nowell
Peter
11-03-2003 13:44:41
 Re: Leaking Transmission Oil on MF TEA 20 (1950's) in reply to Matthew Nowell, 04-02-2003 13:02:16
Matt:
The serial # is at the base of the steering wheel. You should see a plate with serial #,where it was built , etc... Mine is a 1953 with serial TEA335549. Good Luck
