wont start
John G alabama
03-02-2003 15:48:51
I did a major tune up on my 48-8n. plugs points,cond. rotor and cap !!!would not start,took it apart and found that the tower on the base plate had broken loose --fixed it also took up the slake in the shaft and housing!!getting it centered was fun! put it all back together and got spark at the plugs , have plenty of gas and the plugs are new. HELP HELP, still won't start
Gordon
03-09-2003 21:18:30
 Re: wont start in reply to John G alabama, 03-02-2003 15:48:51
Take out #1 spark plug put your finger in the hole turn engine by hand until it has pressure, Check distributor to see if rotor points to #1 plug wire. If not change wires and turn distibutor so rotor points to #1 plug wire. you may have to turn distributor a little to start it. Then time to top dead center.
