Tractor only idles
steve
02-24-2003 14:15:40
have a cub that will only idle with choke fully closed, open choke and it dies have 120#compression each cyl. good spark,rebuilt carb. can anyone help me thank you.
Peabody
02-26-2003 09:07:29
 Re: tractor only idles in reply to steve, 02-24-2003 14:15:40
Do you have a leak on the intake side of the manifold?
tom
02-24-2003 16:22:47
Steve,
Here are some things that you can do based on prior suggestions:
* The notorious "make sure the float is set correctly" as specified by your carb. spec's?
* Is your fuel adjusting needle turned @ least 1.5 to two turns open from the shut position? Is your idle adjusting needle set about 1 to 1.5 turns from the closed position?
* Have you opened your carb's drain cock to see if you get @ least 30 seconds of steady fuel? If not, first check @ gas tank, clean fuel bowl/screen, fuel line, carb inlet valve/screen, etc.
* Do you have new, clean fuel? Use it wisely with today's prices !!
* When rebuilding the carb, did you use a solvent/soaking cleaner? If so, did you remove the main jets and other brass orifices? Did you blow-out and clean all the air-passages and air bleeds? Did you take out the packings in the throttle and fuel adjusting valve? If you left these in and soak the carb., these can dissolve and the smaller pieces can get into your air-passages.
Post back some answers to these questions and let's see where you are.
good luck,
tom
steve
02-24-2003 18:27:20
 Re: Re: tractor only idles in reply to tom, 02-24-2003 16:22:47
float ok,adjusting screws 1.5 on both,blew out all air passages ,clean fuel bowl& screen get good fuel flow,just won't run
case poor in pa
03-01-2003 17:51:05
 Re: Re: Re: tractor only idles in reply to steve, 02-24-2003 18:27:20
i had a super 55 oliver do that.it was the hose from the carb to the air cleaner the inside of the hose seperated and sucked shut . try running it without the hose see what happens. just dont drive thru 5 ft high golden rod with the hose off tho.
evielboweviel
03-04-2003 09:38:45
 Re: Re: Re: Re: tractor only idles in reply to case poor in pa, 03-01-2003 17:51:05
my 66 did the same thing when I first got it. It was grandpa's tractor had been in the family for 50+ years. Gas used to leak out of the carb then everyone thought it quit. Not so was being absorbed by the intake hose, rotting it out until it collapsed inside and tractor would run very rich, no choke to start ever. replaced hose, now shut gas off when not running
tom
02-25-2003 06:39:30
Steve,
TwinCreek sounds like he took it a step beyond adjusting the idle screw...sounds like a good possibility.
Make sure your screws between the upper body and lower bowl is tight, make sure your clamps on the carb and intake are tight too.
Have you checked your plugs to see if they are real dirty, if so, gently file them, re-gap and try again. I have sometimes gone just beyond idling and the engine runs horribly, thinking it was a bad fuel or a fuel issue, later to know the spark plugs were real dirty due to minimal usage and a lot of idling.
Keep us posted and good luck,
tom
steve
02-25-2003 14:57:33
 Re: Re: Re: Re: tractor only idles in reply to tom, 02-25-2003 06:39:30
sand blasted plugs & regaped, screws all tight
TwinCreek
02-25-2003 04:19:41
Sounds like a bad vaccuum leak. Try spraying carb cleaner around the gaskets of the carb and intake manifold while the tractor is running and see if the engine picks up speed. If it does, you found the leak. Be careful though as you are dealing with a hot engine and flammable carb cleaner.
David
03-02-2003 21:34:36
 Re: Re: Re: Re: tractor only idles in reply to TwinCreek, 02-25-2003 04:19:41
I don't agree that it's a vacuum problem. It's a gas problem. It probably is a partially stuck float or a partially plugged fuel filter, since you've already cleaned the carb passages out with air. My old 8N does the same thing when one or the other happens. It's a great tractor anyway. Ask me to tell you a story how my tractor would drive itself at night with no one around, it's scary and true also!
case poor in pa
03-03-2003 18:06:54
 Re: Re: Re: Re: Re: tractor only idles in reply to David, 03-02-2003 21:34:36
sorry you dont agree it happened to me .but then again i dont know evrything either
