MT Hydraulics not working.
tom
02-24-2003 11:42:04
Howdy,
Wanted to see if some could please help give me some ideas on what I need to do to troubleshoot my MT's hydraulics [called a Touch-O-Matic].
No matter what position the control knobs are placed, the lift arms do not move. I have drained and replaced the hydraulic fluids per the operations manual. The PTO works fine when engaged, but no hydraulics.
Thanks in advance,
tom
Dennis
03-12-2003 09:18:19
 Re: MT Hydraulics not working. in reply to tom, 02-24-2003 11:42:04
I am not sure how long you have had this tractor or how familiar you are with it so I will start with the basics. Upon verifying correct fluid level and that the drawbar locks are not engaged, I would check the output of the hydraulic pump to ensure it is working. If so, check input lines to touch-o-matic unit to verify lines are not blocked. If everything works up to this point, it is probably internal to the touch-o-matic unit. Try to manually rotate the rockshaft arms on each side of the tractor. They should rotate somewhere between 45 and 60 degrees. If not, it could be that the pistons are stuck. (This was the problem encountered with my MT which required a complete rebuild of the touch-o-matic unit.) If the arms seem alright, the problem might lie in the pressure relief (by-pass) valves. Good Luck.
