Speedy Sleeves
Super 55
02-23-2003 21:01:31
third party image
Here is a product I found useful for repairing grooves worn into shafts from the oil seals. Some guys fill with JB Weld to repair. I use JB Weld then I install a speedy sleeve or speedy shim. It is a collar that slides onto the shaft. They are available in a number of sizes. I heat mine in oil for easier installation. They come with a tool for installing,but it is generally too short. So, I drill a hole into a board a bit larger than the shaft then push the shim into place. It has a tear off lip that you may have to remove. In some cases I have left it on if it doesn't interfere.
sCOTT in MO
03-20-2003 19:01:27
 Re: Speedy Sleeves in reply to Super 55, 02-23-2003 21:01:31
Just wanted to know where you found the speedy sleeves. And are they priced reasonable. I have a farmall H with several shaft seal groves.any reply would be very useful thanks.
Phil Wiegman
10-14-2006 18:44:52
 Re: Re: Speedy Sleeves in reply to sCOTT in MO, 03-20-2003 19:01:27
You can get the speedy sleves from most IH tractor dealers and many automotive supply houses. CR makes many of them. Hope this helps. Phil
