Third gear Farmall H
sky bartlett
01-29-2003 17:31:03
I was wondering, is it a big job to change the 3rd gear on a Farmall H, or is it a rather easy one after noon fix. Thank you.
Dennis
01-29-2003 18:48:58
 Re: Third gear Farmall H in reply to sky bartlett, 01-29-2003 17:31:03
The tractor is probably going to have to be split to get the shaft out that the gear is on. When you have the top cover off you should check the rest of the gears and bearings over. I was only planning on replacing 5th gear in mine but I found more heavily worn gears and a bearing out when i got it tore apart.
Sky Bartlett
01-30-2003 13:39:02
 Re: Re: Third gear Farmall H in reply to Dennis, 01-29-2003 18:48:58
Thank you very much.
