Torque Tension cylinder head bolts
Marcus
11-13-2001 03:44:34
does anyone know the Torque Tension on the cylinder head bolts of a 1949 fordson E27N.
John Ne.
11-14-2001 21:18:52
 Re: Torque Tension cylinder head bolts in reply to Marcus, 11-13-2001 03:44:34
Remember to start near the middle of the head, and work your way around in a clockwise or counterclockwise direction, so to stretch the gasket evenly. And go in two or three steps, if your final torque is 90, first go 45,,, then 60,,,,being sure they are all evenly torqued as you go, then finally to 90. John in Nebr.
Torque !!!
11-14-2001 16:03:50
don't matter the torque just so all boltes tightened the same.....go to any auto store for torque chart like 1/2 is 70 to 90 9/16 is 85 to 105 etc, etc. also changes for bolt hardness most head boltsare grade 5 but grade 8 1/2 inch bolts torque at 90 to 105 lbs. etc etc.
