Restoration
raymond smith
11-19-2002 10:57:37
When using Martin Senior primer on a 65 Falcon I am running into a problem with it and have on the last 3 cars I used it on. After it is painted and then it rains on the car small blister like appears under the paint, like the primer didn't cure out. I was using Acme Lockson primer and can't find it anymore. Can you tell me what may be causing my problem?? Can I add hardner to the primer??
Larry806
11-23-2002 09:48:26
 Re: restoration in reply to raymond smith, 11-19-2002 10:57:37
Hi We had the same problem with PPG paint The paint Co showed us it was because the hardner we used was opened and not used up in 7 or 8 days. They told us to keep the hardner in the frig. and throw it away after 9 days from opening it Hardner turns to silicone under the paint & blisters if it gets old
