Rubber coming out of harmonic balancer
JERRY
10-26-2002 06:21:21
I have a 4010 JOHN DEERE diesel which has the rubber coming out of the harmonic balancer, any one know if it is fixable?
ET
11-12-2002 06:40:19
 Re: rubber coming out of harmonic balancer in reply to JERRY, 10-26-2002 06:21:21
Put a new one on. Deere recomends a 5000 HR life expectancy on harmonic balancers. They also recomend changing it with any sort of crankshaft failure like spun bearings.
JMS/MN
11-05-2002 00:18:00
Replace it now, or risk sending it through a $900 radiator.
chris
10-26-2002 18:42:55
Not repairable, just buy a new one, a used one isn't worth messing with. chris
Spence
11-01-2002 19:19:37
 Re: Re: rubber coming out of harmonic balancer in reply to chris, 10-26-2002 18:42:55
Check with Damper Dudes .com , I had them restore some old Chrysler dampers , came back like new !!
Antonio Melgoza
12-09-2003 16:56:49
 Re: Re: Re: rubber coming out of harmonic balancer in reply to Spence, 11-01-2002 19:19:37
I have 1953 cadillac I need to fix the harmonic balancer please give me informetion what I need to do if you have any yes to order one. thank you
