Worn cyl heads
damen sharp
10-14-2002 13:16:54
just purchased case 4-cyl. gas,-combustion chambers are alittle pitted.(head was removed by previous owner and remained that way for some time)can iuse awire wheel or something to clean them up or am i looking at costly machinework?-also,cylinders are a bit rusty,can i clean them up without removing pistons?
Jerry B
10-15-2002 08:33:10
 Re: worn cyl heads in reply to damen sharp, 10-14-2002 13:16:54
If the chamber is the heads are pitted then most likely the seats are pitted as well. You can clean the rust out with a power drill and wire brush but the seats will need professional attention.
As far as the cylinder walls are concerned, you can remove the rust with oil and fine sand paper if the rust in just surface rust.
damen sharp
10-15-2002 11:18:49
 Re: Re: worn cyl heads in reply to Jerry B, 10-15-2002 08:33:10
jerry b-thanks for your help!
