Starter on 8n ford
pat lamb
09-14-2002 07:02:37
the stater on the tractor will turn and crank the tractor but when it is turned aloose it goes dead what is wrong
bill w
09-27-2002 18:14:58
 Re: starter on 8n ford in reply to pat lamb, 09-14-2002 07:02:37
Are talking about taking out the starter out and turning it over ? if so then you might have a brush broke in the started or you crushed a brush when you installed the first time around. if the started has only three brushes working it will not turn over the engine . 6vlts sys i'm not sure with a 12 vlt sys but I thnk it will be the same because you are breaking the feild around the armature. you might have to rebuild the started . hope this infomation worked.:)
asherron
09-22-2002 10:43:15
Probably a bad coil resistor
DavidO...say that again
09-18-2002 11:05:28
Are you saying that you can start the tractor and it will run until you release the starter button, then it goes dead? If so, there is a problem in the electrical system somewhere. Be sure that battery terminals are clean and tight. Be sure that battery is properly grounded. If it has the original 6V system, the (+) positive terminal of the battery connects to "ground".Look it over good paying close attention to the wiring. You may spot the problem.
AL
09-15-2002 05:37:50
Are you talking about the key switch? Or exactly what are you turning loose?
