Water in oil
Gregg Kuljian
09-10-2002 13:03:22
I've got a Case 530 that is having water in the oil after running and sitting. The next day I came out and pulled the pan plug and out came half a cup of water. I've been here before and repaired it, but just wanted some fresh ideas and perhaps simple solutions. I previously had sleeve leakage, but fixed it. I can't imagine the head gasket being it, but I'm kind of lazy in the brain after all the work I've done on this gem of a tractor. If the radiator is low, it doesn't seem to happen. Maybe it's not a big deal. Bars leak and forget it? Or is that wishful thinking?
Thanks anyone.
Jerry B
09-11-2002 08:53:10
 Re: Water in oil in reply to Gregg Kuljian, 09-10-2002 13:03:22
I would try K&W Block sealer. It is a ceramic based product that seals very well PROVIDED you follow the instructions. Failure to follow the instructions will result and waste of time and money.
I have used it to seal Ford Escort heads that were notorious for cracking and leaking and they sealed and lasted for years.
One thing I did differently after some experimentation was to NOT drain the block as soon as the treatment cycle was complete, as per instructions. I built a radiator cap that allowed me to put about 15-20 psi of pressure into the cooling system with an airhose.
Following the heat-up and circulation cycle I applied the air pressure, ran the engine again for about 10 minutes. This allowed the pressure to push the material deeper into the cracks and leaks. I let is set for about 6 hours to cool and let the pressure drop. Then I opened and drained the system and let everything dry over night.
Gregg Kuljian
09-11-2002 10:27:40
 Re: Re: Water in oil in reply to Jerry B, 09-11-2002 08:53:10
Great ideas. I'm pretty sure it ran low on water, the orings overheated, and now leaks. I was thinking of taking the oilpan off and literally seeing where the water is coming from. That way I'll only have to pull the one bad sleeve. Hey, I'll use your ideas, and I'll bet I don't have to worry. I was just out mulling over all the other things life has to present to us, and the tractor isn't the biggest priority. The barn roof drains and the foundation has settled enough to break a 24 foot long solid redwood 6x6 beam. At least I've got a barn. Thanks again,
Gregg K
