MH Won't Start Help
Mark
09-04-2002 09:15:41
My MH44G began running rough, backfired and will no longer start. I have cleaned and rebuilt the carb, flushed the gas tank, installed an inline fuel filter, replaced Dist. Cap/rotor, points/ condensor. I have spark at the plugs and did a compression check 90lbs.,95lbs.,100lbs.,100lbs.
I also replace the starter switch after it fried from trying to start it too many times.
What else can I try? Remove the valvecover and see if the valves move? Thanks for any help!!!
Don LC
09-05-2002 20:37:18
 Re: MH Won't Start Help in reply to Mark, 09-04-2002 09:15:41
Since you have done all this work and replaced all these parts-----the valves have to be opening and closing or you couldn't get compression readings ...the cyl.are only 10# apart, that is OK..... check timming,could be a proublem there.....check to see if gas is getting in the cyl.....
