Marvels Mystery Oil, Any Good?
Bob (WI)
10-30-2001 17:15:07
What does everyone think of Marvels Mystery Oil? is it any good or is it running on it's reputation like alot of other products from years past? If it worked I would like to know what you used it for and for how long.
Bert
11-18-2001 19:03:59
 Re: Marvels Mystery Oil, Any Good? in reply to Bob (WI), 10-30-2001 17:15:07
Mostly kero with other solvents plus a nice peppermint scent.
Works to ungum fuel sytem.
Use as directed, will cause smoke if overused.
Dont put it down cylinders like some advise, crud it loosens can cause a clog downstream.
Wife was stuck- - - - - - -
11-09-2001 14:59:10
in the bath tub so I poured a little in the water. Finally found her about half a mile down the sewer pipe.
rem
11-06-2001 06:05:23
Hi,
I used it in an AC-CA that wanted to plug foul all the time under heavy load. MMO solved the problem.
Today, I use Hydrotex additives in all my oils and the fuel for my Ford 3000. Less down time.
Worth the investment.
Paul Stanley
11-02-2001 22:42:25
I used it to remove rusty ubolts and hubs on my Super 55. Works great. I like the smell of it. Liguid Wrench penetrating oil gives me a headache when I smell that stuff. There was a tall tale going around of the fellow who had a rusty nut frozen on a bolt. Put the bolt head in the vise, put on a few drops of Marvel Mystery Oil on the nut. He then went to bed and in the morning when he returned the nut was laying on the floor. :P
Gary V
11-01-2001 17:54:58
I added it to the gas and oil in my Co-op E-2 after I got it running and I have to believe it runs better with it.
Bill Jpnes
11-01-2001 13:52:01
It was originaly used by GMC truck factories in the 20's and 30's to dissolve gum and varnish deposits in Marvel-Schebler carbs when they came in for rebuilds or were not running right. Nobody knew the contents of the oil,so it was a "Mystery" as to how it worked,so the GMC workers dubbed it"Marvel {Schebler} Mystery Oil"and the name stuck or unstuck if you please.;^} BillJ
oops!
11-01-2001 16:01:04
 Re: Re: Marvels Mystery Oil, Any Good? in reply to Bill Jpnes, 11-01-2001 13:52:01
Actually there is no "p" in my last name! Bill Jones:^}
Joe
10-30-2001 22:38:17
I know some people swear by it religiously. I have used it some and like it fine. It's not just a name, it seems to be the real deal.
Redtractorman
10-30-2001 21:24:46
I put it in the gas or diesel feul when I add to the tank,bought a Case Sc that if sat for more than a month valve would stick,started adding this to oil and it never sticks anymore,even after sitting for months.
Doc
10-30-2001 21:05:33
Makes a great lube for air tools. A few drops in the inlet works good. My 25 yr. old CP 734 impact has the same power as new. It would also be one of my first choices for soaking a stuck engine I was trying to loosen. Doc.
Richard
10-30-2001 20:11:46
I had a stuck engine. I soaked it loose with mystery oil in about 6 months or so. I started by checking every other day , then every week, then I just left it alone for a couple of months, the next thing I knew it was loose! Be patient.
Bus Driver
10-31-2001 18:13:37
 Re: Re: Marvels Mystery Oil, Any Good? in reply to Richard , 10-30-2001 20:11:46
When tapping in cast iron to put in thread inserts, the Marvel works well as a tap lubricant. Makes it turn much easier. The stuff smells as if it has kerosene in it, but obviously has other things also.
