Swap MT motor into Deere 40
Lance
07-10-2002 17:53:59
The block on my John Deere 40 has a 1 inch crack through the top of a cylinder and head bolt hole. A local shop said they can weld it and then sleeve the cylinders. I also can buy a John Deere MT block.Is the MT block the same as the 40? Or am I better off boring the cracked block and putting in sleeves.Please email any advice or leave note on board. Thanks [email protected]
JDM Guy
07-12-2002 14:37:53
 Re: Swap MT motor into Deere 40 in reply to Lance , 07-10-2002 17:53:59
Sure, swap them. The 40 series was the replacement for the M series. So basicly you can swap just about any thing. The later tractors like the 320-330-420-430 had water pumps so you cant use motor parts from those models.
