MF TO20
Bailey
06-21-2002 12:59:03
Still having problem with my TO 20..it will die on me after 10 minutes or so..when it starts to die I pull the choke out part way & it will run a while longer..have rebuilt the carb, replaced wires, points, condenser, plugs, dist cap, and coil..
I notice condensation on the intake manifold just before it starts to die..
Any help will be appreciated..am about ready to shoot it...
Alton
06-22-2002 17:50:22
 Re: MF TO20 in reply to Bailey, 06-21-2002 12:59:03
Take out plug at bottom of carb and check fuel flow. Should be a good flow after carb. bowl emptys. Gene could be right if you are getting flow to carb.
GeneDavis
06-21-2002 13:15:31
Some times a restriction in the carb venturi or a jet will form ice in cool damp weather and restrict itself Gene Davis
