Wiring up a hour gauge
Tye
06-08-2002 03:12:43
Can anyone help me here- I have a jc whitney hour gauge with one positive and one negative wire hook up. Where on the tractor do I hook up the positive and negative wires? Any help would be greatly appreciated. Thank you!
JK
06-09-2002 06:26:39
 Re: Wiring up a hour gauge in reply to Tye, 06-08-2002 03:12:43
Tye,
Assuming your tractor is a negative ground system (The "-" battery terminal is connected to the tractor frame) and has a distributor type ignition system:
The negative wire connects to a good ground (frame) and the positive wire should be connected to the same terminal on the ignition switch as the wire coming from the coil so it has power to it only when the ignition switch is turned on.
If the tractor is positive ground ("+" battery terminal is connected to the tractor frame) simply reverse the wires to the hour meter.
John
Two Bit
06-08-2002 20:52:48
It matters as to What kind of tractor it is?
