Super Oliver 55 pulley
Jack
05-31-2002 19:24:09
I need to know if I can replace a broken fan/water pump pulley behind the radiator with a double pulley and just not use one of the pulleys.
The pulley I need is not available in our area. Our 13 yo son - this is his tractor and he is lost without it.
Thank you
jake
06-02-2002 08:41:05
 Re: Super Oliver 55 pulley in reply to Jack, 05-31-2002 19:24:09
Call or e-mail www.wegners.com, 1 800 451 5210. I deal with Ken Roher. It's easier to get the right part. I don't believe the pully will clear the engine mounting casting if my memory is correct and unbolting the frame and sliding it forward involves some work.
howard
06-01-2002 17:39:21
are you asking if it will fit or if you can make it work? I'd say if you can see to make it work, go for it! otherwise there should be some oliver guys out there that can help you.
