Restoration & Repair Tips Board
front end alingment
in sticks
05-10-2008 10:11:55
bent the tie rod on tractor, now that it,s sorta straight.what is the correct alingment on front wheels? toe in,toe out,or neutral
jose bagge
05-11-2008 05:42:08
 Re: front end alingment in reply to in sticks, 05-10-2008 10:11:55
1/8 to a 1/4 toe in....they will toe out as you move forward, so add more toe in as your front end components get sloppier.
jose bagge
05-11-2008 11:12:32
 unless 4X4.... in reply to jose bagge, 05-11-2008 05:42:08
if it's 4wd and you use it in 4wd mostly, toe it out about a 1/4"... drive wheels usually induce toe in as they drive forward
Welding man
05-10-2008 15:20:31
Don't know what kind of tractor you have but we set most of the ones we deal with 1/4" toed in. If you toe them out they shimmy when on the road at high speed.
