Restoration & Repair Tips Board
oil pressure
Ricard Kottke
05-02-2008 07:09:26
I have been restoring a 1947 styled John Deere bu have ran into a problem. How do I adjust the oil pressure, I bought new guages but Idon't know if they are the right ones. I could sure use some advise. Thanks, Richard Kottke
greenmech
05-02-2008 14:56:06
 Re: oil pressure in reply to Ricard Kottke, 05-02-2008 07:09:26
There is an adjustment, usually on top of the oil filter canister. Access is thru the crankcase cover.10 - 15 psi is normal. Ron Mn.
Jerry/MT
05-02-2008 14:51:14
The bearing clearance and the pump pressure flow characteritic sets the oil pressure. There is normally a relief valve to allow by pass flow during cold conditions but when the oil warms up, the relief valve should close and the oil pressure is then determined by the bearing clearances and the pump. The relief valve can stick open and that would cause low oil pressure even with good bearings.
If you have a problem with low oil pressure, check the relief valve first and consider replacing the pump. They do wear out. If a pump replacement doesn"t fix it, then you are looking at bearings but you"ve got a new pump and I always recommend a new pump with a rebuild.
CNKS
05-02-2008 08:55:51
I'm not a JD person, but the only way you "adjust" oil pressure is to overhaul the engine, unless it's something simple like a worn oil pump. If it is not the pump it is crank and/or cam bearings. JD forum can tell you which are the right gauges.
noncompos
05-02-2008 10:43:09
 Re: oil pressure in reply to CNKS, 05-02-2008 08:55:51
Some engines do have an oil pressure adjustment, altho it's completely true that nothing will help worn bearings.
CNKS
05-02-2008 12:40:56
 Re: oil pressure in reply to noncompos, 05-02-2008 10:43:09
I doubt if there was an adjustment on a 47 JD, unless the pump itself was defective.
noncompos
05-02-2008 15:54:06
 Re: oil pressure in reply to CNKS, 05-02-2008 12:40:56
I"m sure you"re correct on the JD; I misunderstood your comment to mean engines in general.
