Restoration & Repair Tips Board
Steering wheel crack repair.
greenbeanman in
04-10-2008 12:31:28
While I know that I have seen this topic covered before I'm not having any luck finding those threads.
Seems I remember JB Weld and fiberglass body putty mentioned, but I also seem to recall that another product was considered even better.
Can you enlighten me? Also what to use for a coat over the refurbished wheel, just a durable paint or some sort of Plastigrip?
Thanks.
patsdeere
04-11-2008 22:25:14
 Re: Steering wheel crack repair. in reply to greenbeanman in Kans, 04-10-2008 12:31:28
I used a 5 minute epoxy and filled all sizes of holes. Let it setup and dry real good and then just sand it down. After I got it smooth I shot it with about 5 coats of that rubber spray in a can. It looks great, works great and hasn't left my hands all black and nasty.
JMS/.MN
04-11-2008 22:04:49
JB weld works fine- I"ve found that it helps to use a split hose or something similar to maintain shape around the steering wheel-then remove the hose and grind/file the excess away.
LeRoy DeLong
04-11-2008 11:02:15
Go to your local NAPA store and get a product called POR-15. It's an epoxy putty and you get two bars. Cut an equal amount off each bar, mix together and work it on. I paid $19 for mine.
I have redone the steering wheel's on an Allis B and Farmall B and still over half of it left. Great results.
LeRoy
Chief 83
04-10-2008 21:59:26
I just fixed one also. I used a couple of different products. For the small cracks I used JB Weld. I used a toothpick to kind of smoosh it in there. Sanded it off when hard. It took two or three "coats" in some of them. I also had a couple of large chunks missing. I used epoxy putty for those. I'd never used the stuff before but now I'm sold. I'd probably try it in the small cracks too. Good stuff and quite inexpensive.
04-11-2008 08:26:54
 Re: Steering wheel crack repair. in reply to Chief 83, 04-10-2008 21:59:26
Thanks. I have seen epoxy putty in stores but never thought I had a use for any. Using it actually sounds better to me than mixing JB Weld.
Gotta get busy, my hometown has an antique tractor parade coming up in early May.
Ken 46
04-11-2008 11:31:25
 Re: Steering wheel crack repair. in reply to greenbeanman in Kans, 04-11-2008 08:26:54
What is your home town?? When is the parade?? I live in Far SW Kansas - if you are close we might show up!!!!
04-12-2008 07:13:16
 Re: Steering wheel crack repair. in reply to Ken 46, 04-11-2008 11:31:25
A flyer is supposed to be mailed to me any day now from a cousin.
What little I know now---Utica, Kansas in Ness County. Parade generally late in the day around 3 or 4 p.m.
I've not attended one in the past but understand it is a decent event for such a small town (200).
This has been going on several years now, perhaps 5.
I'll post more after getting the flyer.
NOHOG
04-10-2008 14:59:55
I just repaired mine this afternoon using JB weld. I found the right stuff on the Eastwood Co website(do a search). But decided on the JB weld (cheaper). V shape all cracks, apply JB pressing deep into cracks let dry, file, sand ect. Next apply a etching primer (NAPA makes a very good one in a rattle can) sand smooth paint black and could clear coat all with rattle cans
Hope this helps
NOHOG, KS
greenbeanman in Kansas
04-10-2008 18:15:37
 Re: Steering wheel crack repair. in reply to NOHOG, 04-10-2008 14:59:55
Thanks. I have a current Eastwood catalog but haven"t looked through it. Maybe that is what I was remembering about.
I don"t mind going to my local NAPA store at all. The manager is a very nice young lady, and it doesn"t hurt my feelings that she is attractive too.
Expect I would be buying a lot of parts if I were 20 years younger.
Again, thanks
