Restoration & Repair Tips Board
jd B oil head,filter
R.Mc
04-09-2008 14:44:11
whats the trick to getting these old things out? i noticed that mine has rusted all the way through. In my book it says theres screws to get her out but im not finding any? any help would work
Maark
04-15-2008 19:46:19
 Re: jd B oil head,filter in reply to R.Mc, 04-09-2008 14:44:11
you will need to remove the oil filter, look up inside, you will see a tin pipe with a steel washer attached, Take a 1/4" rod, make a hook on 1 end. That steel pipe has a hole in it to pull it down. You will then see the 3 screws the book talks about.
