JD 630 Seized Hub
M Chamberlain
05-18-2002 19:31:25
I have a 630 JD that has a seized hub on the left rear axial. The gear that moves the hub in and out on the axial was broke when I bought it. I can't get anyting to move because of the rust seizure. I have removed the rim and tried to pull the hub off, but nuthing I have tried works, and I don't want to get to agresive with it becase it is maid of cast iron. Can anyone give me some tips?
David B
05-19-2002 16:57:58
 Re: JD 630 Seized Hub in reply to M Chamberlain, 05-18-2002 19:31:25
After losening the three bolts and tightning the two smaller bolts that are supposed push the wedge loose, I always use penetrating oil and a big hammer on the small bolts, If you hit the big bolts make sure the are backed out just a little bit or you will damage the threads. Just keep tightning on those two bolts and hitting them. Eventually it will loosen.
kevin
05-19-2002 09:12:40
use lots of penatrating oil.Tighten the lock as if your going to take the wheel off.Get a BFH and hit the end of the axel.This in time should break it free.Using a torch in my opion dosen't work well.Keep using that oil.
