Restoration & Repair Tips Board
cutting a hole in a loader tire
wally b
04-03-2008 07:54:36
I have a skid loader tire that weighs about 600 pounds, that I pull with my draft team to keep them in shape for the farm season. I want to cut a hole thru the tread surface so I can thread a chain thru so the chain won't drag underneath the tire (the friction on the grab chain eventually breaks the chain)
What would be the best way to cut a 2in by 2in approx hole?
wally b
jose bagge
04-06-2008 04:35:47
 Re: cutting a hole in a loader tire in reply to wally b, 04-03-2008 07:54:36
a regular "spade bit" wood drill bit will drill right through....a sawzall with a wood blade will cut it up any way you want from there.
wally b
04-04-2008 08:30:13
thankyou
wally
robert shields
04-03-2008 16:20:13
use a 2x2 heavy wall tube grind a taper on 4 sides of one end heat cherry red and push thru tirs
south paw
04-03-2008 16:13:50
use a 2x2 heavy wall square tube grind all 4 sides to asharp taper heat the end cherry red and push it thru the tire
glennster
04-03-2008 08:57:52
i use a hole saw bit and a bottle of dish soap for a lubricant. works pretty good.
