Restoration & Repair Tips Board
hard starting Cub lo-boy
Raymond Piantan
03-31-2008 17:54:44
Hello folks, Question on a Cub lo-boy: Can't get the engine to run more than a few seconds at a time. Thought it was sediment in the tank so I pulled the tank off and put tank liner in it. Still nothing. It does fire, but won't stay running after the starter is disengaged. I'm not an expert rebuilder, so I thought I'd seek some advise.
Thanks,
Ray
glennster
04-01-2008 10:22:58
 Re: hard starting Cub lo-boy in reply to Raymond Piantanida, 03-31-2008 17:54:44
i would try to eliminate the electrical system first as the problem. get a length of 14 to 16 ga insulated automotive electrical wire with alligator clips on both ends. at the coil, hook one end up to the terminal opposite the one that has the small wire going to the distributor. hook the other end up to the battery post that is the hot side. not the post that grounds to the tractor. you are either + or - ground. then see if it starts and runs, you will need to remove the wire to shut the tractor off. if it stays running with the wire connected, its a wiring issue.
Raymond Piantanida
04-01-2008 17:41:52
 Re: hard starting Cub lo-boy in reply to glennster, 04-01-2008 10:22:58
I will give that a shot. Thanks, Glennster.
soundguy
03-31-2008 19:17:59
Ya didn't re-wire something to makethe coil only hot while the starter was engaged did ya?
soundguy
Raymond Piantanida
04-01-2008 05:17:58
 Re: hard starting Cub lo-boy in reply to soundguy, 03-31-2008 19:17:59
Don't recall doing that but I will sure check. Thanks
Raymond Piantanida
04-01-2008 17:43:29
 Re: hard starting Cub lo-boy in reply to evilboweviel, 04-01-2008 08:53:36
Will check that out. I'm a newbie here. Thanks for the suggestion.
Ray
