Restoration & Repair Tips Board
Repair options - cast pivot
Osterbur
03-29-2008 08:26:34
third party image
Looking for advice on fixing this pivot point for
a loader bucket. It"s cast with a 1 inch hole.
TIA Lynn
Picture posted in Parts and PIeces -
shawnspeed3
03-29-2008 08:42:31
 Re: Repair options - cast pivot in reply to Osterbur, 03-29-2008 08:26:34
Well , it appears to be cast steel, and not iron , because they welded it originally to the loader arm. So, you can get a piece of 1" id tube ,with at least 1/4 " wall and weld it in(trim casting and tube to fit in close alignment, with tight gaps) to repace the broken portion, using a 1" pin to keep it all lined up, or weld it all back up and try to get a 1" drill back down the bore to clean ot up,(good luck). Repacing with tube will take a little longer fitting everything up , but should gove you a nicer stronger fix....Good luck Shawn
