Restoration & Repair Tips Board
genarators
Mark Post
03-02-2008 14:51:51
Can someone tell me when converting a 6 volt genarator to a 12 volt genarator is the tractor still positive ground or is it negative ground.
Bob
03-02-2008 20:57:17
 Re: genarators in reply to schoffie, 03-02-2008 14:51:51
If you are going to change it to 12 Volts, I would go to (-) ground, as most folks nowadays are NOT familiar with (+) ground, and with (-) ground, there will be less chance of error when someone installs a new battery, charges the battery, or "jumps" it.
CNKS
03-02-2008 17:23:53
 Re: genarators in reply to Mark Post, 03-02-2008 14:51:51
As the others said the generator does't care. However, on a 6 volt system, if the regulator is designed for positive ground and you have neg ground, the contacts in the regulator wear faster. I don't know if this also happens in a 12 volt system, but most(all?) factory 12 volt systems are negative ground, generator or alternator. If it was my tractor, and I had a 12 volt generator, I would use negative ground.
Mark Post
03-03-2008 12:30:19
 Re: genarators in reply to CNKS, 03-02-2008 17:23:53
Thank you guys so very much for your help on the genarator.
55 50
03-02-2008 17:36:52
All old JD 2 cylinder 12 volt systems were POSITIVE ground from the factory. Those that have been converted from generator to alternator are switched to negative ground because, as John T said, most alternators require negative ground.
CNKS
03-02-2008 17:50:02
 Re: genarators in reply to 55 50, 03-02-2008 17:36:52
Varies by manufacturer. I'm not sure about the last 4 cyl large (350, 450, etc) Farmalls that went to 12 volt, but the replacement 6 cyl were neg ground. Also, as to the voltage regulator, not all 6 volt reg had to be positive ground and not all 6 volt systems were positive ground. I merely mentioned the regulator in case it was specifically designed for one or the other, in case there were problems later on. I also forgot I wasn't on the Farmall forum, as the 6 volt Delco regulators IH used say on the bottom, "6 volt positive ground. I was wondering if there were any 12 volt regulators that said + or - on them.
John T
03-03-2008 07:29:58
 Re: genarators in reply to CNKS, 03-02-2008 17:50:02
It varies by manufacturer. Over the years Ive seen regulators labeled Pos Grnd,,,,, ,Neg Grnd,,,,,Some not labeled,,,,, some for either..... . (did I miss any lol) I agree with you as Ive read literature claiming it (polarity sensitivity) has to do with the coatings on the relay contatct points and that makes sense as electrons have a mass and in DC applicatiosn where curent always flows the same direction electrons would always be flowing from one contact and bobmarding the other.
OTHER reasosn why a VR would be for one specific polarity is where diodes (polarity sensitive device) are used for spike suppression purposes.
ALLLLL L 2 cylinder Deeres were Pos ground regardless if 6 or 12 volt while IHC made some changes away from Pos when they went from 6 to 12 volt...
Yall take care now
John T
John T
03-02-2008 17:10:03
The genny can charge n work fine at EITHER polarity provided you polarize it regardless if 6 or 12 volt or Pos or Neg ground. I wouldnt change its polarity cuz if you do then you have to swap ammeter leads n change coil wiring (plus add ballast if you use a 6 volt coil on a 12 volt systerm) if its a coil ignition. That having to switch to neg ground for 12 volts you hear tell of concerns an Alternator cuz most of them are for Neg ground only.
John T
Pappy
03-02-2008 15:17:52
Your polarity can be the same. No need to change it.
mark post
03-02-2008 16:03:54
 Re: genarators in reply to Pappy, 03-02-2008 15:17:52
thanks for awnsering. my dad said it had to be negitive ground because it is going to be 12 volt. will it hurt a genarator if you made it negative ground. im greak to all this its my first tractor.
