Restoration & Repair Tips Board
davis case trencher-backhoe 580b
olchief
03-02-2008 09:24:14
drove tractor to park it with normal transmission pressure. upon trying to move 2 days later it refused to move and transmission pressure was just at lower edge of green line on gauge. trans. oil found low, topped up level with no increace in pump pressure.upon starting had excessive noise in shuttle system,probably indicating air entrainment-loosened lines on both shuttle outlets on left side tractor and cannot clear air from this system.pump operates in same manor as previous discription. pump continues to pump oil and air but not enough to operate motion back and forth. when shuttle is shifted only tiny jolt in either direction.tractor filter system has been examined and is good.where can air enter with flooded pump suction? any help with this problem greatly appreciated. olchief
dieselpaul
03-02-2008 11:26:19
 Re: davis case trencher-backhoe 580b in reply to olchief, 03-02-2008 09:24:14
hello. are you checkng fluid with engine running? i am not certain, but believe that is proper way. if its the shuttle i'm thinking of, it has very little reserve in the lttle pan that filter sits in. also o-ring on end of filter tube checked? good luck-paul
