Restoration & Repair Tips Board
live pto on Super M
Scott S
02-27-2008 15:02:56
Is there a way to convert a Super M to live PTO using existing rear end,transmission,clutch? If not will a 400 rear bolt to a Super M engine? What are my options?? ( no i will not get rid of the tractor)
Nebraska kirk
02-27-2008 17:04:28
 Re: live pto on Super M in reply to Scott S, 02-27-2008 15:02:56
There is no way to make a super M have live PTO without changeing the rear end. Yes, a 400 rear should bolt right up to the super M engine. You will have to use a 400 pressure plate though as PTO is driven off of it. The M&W gear company made a hand clutch for the Super M, it installed in place of the left brake, all it did was to disconnect the left side final drive allowing you to stop forward motion without interupting power to the PTO. You still had to use the foot clutch to shift gears though.
Scott S
03-03-2008 09:06:36
 Re: live pto on Super M in reply to Nebraska kirk, 02-27-2008 17:04:28
Thank You for the reply!!
