Restoration & Repair Tips Board
farmall h hydraullics
Larry Caldwell
02-24-2008 14:56:38
I want to hook up a 3 pt. and remote on my h how do you plump the lines
glennster
02-24-2008 16:07:30
 Re: farmall h hydraullics in reply to Larry Caldwell, 02-24-2008 14:56:38
pretty easy to do, i assume you have a belly pump,. not live. pick up your dual remote valve, open center. take one of the output lines from the belly pump, plumb it to the in side of the valve, the return line from the valve can go either to the belly pump drain plug with a pipe tee, or to the fill pipe with a pipe tee. to operate, the control rod must be in the full back position to operate the remote valves. what i did was mark the control rod in the full back position where it goes thru the support, and tack weld a short stub of a 3/8 bolt to it. it will look like the stop that is already there, then just pull the rod back and hook it on the second stop.
rlk
03-16-2008 18:25:08
 Re: farmall h hydraullics in reply to glennster, 02-24-2008 16:07:30
Can anyone tell me where the drain plug is for a Farmall H hydraulics fluid? I looked all over mine this afternoon and have not found it.
Thanks, Bob
