What ckt type is this genny / regulator? Hint.. flip the reg over... look at the bias resistor(s) underneath to determine circuit type. A circuit: Bias resistor from ground tab to FLD tab. B circuit: Bias resistor from ARM/GEN tab to FLD tab.. may have another bias resistor. Now.. once you determine the field type... Motor test your genny. slip belt off genny, disconnect ALL wires. hook arm/gen to bat Hot. If it is A circuit, then ground the Fld post. If it is B circuit, lump hot to FLD as well. Most gennies that motor, will charge.. most gennies that charge.. will motor. If it is A- circuit, you can put it back together and leave F wire off and then start up tractor, grounding F post on Genny will make max charge. If it is B circuit, leave F wire off, but jumper F post to bat hot and it should make max charge. If still nothing at battery.. jumper arm to bat across the regulator.. it may have a bad cutout.. repeat full field test for circuit type. post back if you have questions.. if you know circuit type.. post it.. makes diagnostics easier.. soundguy
