Restoration & Repair Tips Board
hydralic plate leaks
Jack Clouse
02-09-2008 13:47:31
The block off plate for the hydralic oil is leaking real bad. I took it off and it is just a plate with O rings and I put it back together and it's worse. What is the best way to stop the leaking.
UU
02-14-2008 05:20:25
 Re: hydralic plate leaks in reply to Jack Clouse, 02-09-2008 13:47:31
Make sure to clean the plate properly.there are some pads called GRIT SURFACE CONDITIONING KIT at harbour freight $12.99 these clean the metal real good . Once both surfaces are cleaned and new gasket used just torque it down in a cris cross pattern & you should be good to go....
Amarillo Doug
02-09-2008 18:35:48
Make sure the plate is flat and replace the Orings,torque the hold down bolts in a criscross pattern evenly and it should stop leaking
