Restoration & Repair Tips Board
Schwartz hyd cylinder seals
Farmer Keith
02-02-2008 13:32:05
Wonder if anyone has had to replace the Chevron seals in a Shhwartz loader, and if so, where you found the seals. I'm being quoted $106 per side. Sounds pretty steep.
Cheers
dave2
02-06-2008 07:29:26
 Re: Schwartz hyd cylinder seals in reply to YTSupport, 02-02-2008 13:32:05
for my baas cylinders it was about $70 each cyl. I bought one and took it to a hydraulic repair shop (in a sandwich bag) and matched the rubber and reused the metal washers. Gave a block of coffee for the seals.
JMS/.MN
02-03-2008 10:33:42
 Re: Schwartz hyd cylinder seals in reply to Farmer Keith, 02-02-2008 13:32:05
Seal kits for JD148 are about $50 per cylinder. If you have yours apart, you may find the need for only a part or two. Check with hydraulic shops if individual parts are available.
Lynn Davis
02-03-2008 09:14:55
Yes, but divide that by number of years since last replaced. Sorry, just had to throw that in since I can't give an accurate, intelligent or reasonable answer. Does sound a bit high.
