Restoration & Repair Tips Board
Farmall H manifold
farmerphil1
01-29-2008 19:11:54
I have an all fuel manifold that has a 1/2 " hole in it, what is the best way to fix this? Thank-you, Phil
Andy Motteberg
01-30-2008 16:57:47
 Re: Farmall H manifold in reply to farmerphil1, 01-29-2008 19:11:54
You can weld it, or have it welded by someone else. I myself don't really like welded up manifolds, so if yours has been repaired previously, I recommend finding a different manifold or a brand new one.
Andy.
george md
01-30-2008 21:28:46
 Re: Farmall H manifold in reply to Andy Motteberg, 01-30-2008 16:57:47
Andy, It appears you don't have any experience with o/a cast iron welding , not with nickel, not with brass, but with a torch , a can of flux , and real cast iron in a stick. Before you condem it you need to do some research , I fix many things that the parts changers say cannot be repaired and usually for a lot less than a replacement .
george
Andy Motteberg
02-01-2008 20:56:20
 Re: Farmall H manifold in reply to george md, 01-30-2008 21:28:46
"Andy,
and real cast iron in a stick. Before you condem it you need to do some research ,"
What are you talking about? I never mentioned anything about what kind of weld to use or how to do it, so how would you know anything about my "experience"???
george md
01-29-2008 20:11:35
Phil, The proper way to repair a cast iron manifold is to weld it with o/a and cast iron in stick form. I repair manifolds regularly , Most often you need preheat and post heat . I did an M dual fuel with a small hole ,the material around the hole burned and rusted meaning you have to make larger hole to get back to good base material.
george
third party image
Showing back of the broken heater box
third party image
assembled box , back side
