MF TO 20
Bailey
05-06-2002 05:00:12
My TO 20 starts to die on me after running for approx. 5 - 10 minutes. Acts as though it is out of fuel. Rebuilt the carb..did not help. Had a cracked manifold leaking on to the fuel line. Thought it may be vapor lock..replaced did not cure.
Any suggestions.
Bailey
Jerry B
05-06-2002 06:38:34
 Re: MF TO 20 in reply to Bailey, 05-06-2002 05:00:12
Make sure the fuel tank is venting properly. Check to make sure the coil is firing as it starts to die out. If not you may have a coil, points, condenser or coil wire getting hot and breaking down.
