Restoration & Repair Tips Board
Transmission/drive shaft shims F-20
Russ926
01-17-2008 09:02:46
So how do you get a measurment to check clearance between the transmission bearings and on the other end where the output shaft comes through the 'hub'??? I sold my heisler overdrive and replaced with original shaft and ruined the shims when it came apart.. I have no idea what or how to do this to make sure things are tight enough.
