Restoration & Repair Tips Board
spinning shift lever
DS Mi
12-16-2007 17:01:03
Shift lever on my b spins. It's annoying. pulled snap ring, washer,and lever out and can't see what keeps lever from turning. help please. ds
hdguy
12-19-2007 19:38:09
 Re: spinning shift lever in reply to DS Mi, 12-16-2007 17:01:03
Hello, Have you tried to see if the dowl pin is loose in the shaft at the bottom of the lever, if it is or it pops out or gone you may wanna put and oversize dowl in the hole or if the pin is still there you can JB weld it, but it would be better to put an over size dowl in its place. Learned this from my buddies that pull Allis's. Hope its not to severe....
Ray
DS Mi
12-17-2007 17:56:12
Sorry I was lost. It's an allis 39 B.
rrlund
12-18-2007 06:57:44
 Re: spinning shift lever in reply to DS Mi, 12-17-2007 17:56:12
As long as the shift is straight,it's not a problem,but my 1020 is a loader tractor. I left it sitting in the feedlot while I was out with a load of manure one time. When I got back,the bull had his ring over one of the shifts and couldn't get it up past the knob. He was pulling so hard he was skidding the tractor sideways a little every tug. He bent the shift. Now you have to make sure it doesn't turn while shifting. If it does,you run the risk of it jumping in the fork and hanging in two gears at once. I've had to take it apart twice to get it out of gear. I've straightened it some,but I'm afraid of breaking it.
rrlund
12-17-2007 07:05:03
If it's an Allis,yes they spin. So do both shifts on my 1020 JD. It's just the way they are made. A ball in a socket with a point that goes in to the fork.
old
12-16-2007 19:14:56
B what?? Farmall Allis JD?? helps to know that
