Restoration & Repair Tips Board
PLEASE Case 530 - transmission problem ?
Orphee
12-03-2007 14:03:07
Hello
I have a BIG problem: my case 530 dont't want more going reverse or forward.
Motor works well (perfectly !) but, recently, I had to play frequently the clutch to make it working.
Now it's doesn't work anymore. My question is this one: is it possible the transmission oil is too low ?
Note: when I push the clutch with my foot I heard the usual noise but the wheel doesn't turn.
My case is in the snow (BIG snow) and in front of my car so I'm quite jammed !
Thanks for your help.
Please send me a mail to [email protected]
Sorry for my bad english
Mike in MI
12-03-2007 16:34:51
 Re: PLEASE Case 530 - transmission problem ? in reply to Orphee, 12-03-2007 14:03:07
What year is your 530? Has the clutch been slipping before hand? Sounds to me it lost the facing on the clucth plate. Mike
Orphee
12-03-2007 17:05:29
 Re: PLEASE Case 530 - transmission problem ? in reply to Mike in MI, 12-03-2007 16:34:51
I think it's 1960
I bought this one year ago, pay it too much (7500$) and you can add about 2000$ for repair ... (sorry I'm not a mecanician, just electronician)
So, as you can see, it's a very good operation for a tractor you doesn't work today.
Perhaps it's better I give you some precisions:
Last time, a few weeks ago, I had this problem too.
At the beginning I was thinking I can't do anything but, moving the right lever (long or short transmission) and using the clutch pedal, I was able to move forward or reverse. So I was thinking this was a simple mecanical problem (used parts).
This morning I work with it (for snow) and all was as usual: not too much problem to make it fw/rev. Note that, when it's work, it works good until I push the clutch.
Probably tomorrow I will arrived to put the case so it doesn't matter for my car because, in 15 mn of trying, I will arrived to make it working ... until I push the clutch again !
I search on the web and I'm quite disapointed: it seem that 530 often have cluch problem and need to take the motor out to repair.
If so, I doesn't know what I do because price become too much for me.
