Restoration & Repair Tips Board
oil seal replacement for a 1969 430 case
martin42
11-28-2007 12:05:21
Hi , could anyone of you know how to replace a wheel oil seal for a 430 case, i bought a shop manual, and there"s nothing in it, it"s the left side, and i"m loosing all my tdh oil...thank you
LarryNeohiocase
12-06-2007 06:59:53
 Re: oil seal replacement for a 1969 430 case in reply to martin42, 11-28-2007 12:05:21
Martin,
It should be pretty self explanatory. Send me a pic of the wheel that is leaking and I may be able to talk you through it. It's nto really that difficult. Where are you located?
Larry
martin42
12-06-2007 19:43:26
 Re: oil seal replacement for a 1969 430 case in reply to LarryNeohiocase, 12-06-2007 06:59:53
Hi Larry, i'm in Rawdon(one hour upnorth of Montreal) , Quebec ,Canada,....the main thing is that it's suppose to be very easy(everybody says so ), but i can't see how it's pull out of there, taking out the wheel should be easy but how to take out the oil seal, there's no grip, some tractor model have a plate and four bolts to hold the oil seal in place, but not mine, look like it's a thigh fit, i though about driling a hole or two and placing screws and pull it out , i wanted to order the part before taking out the oil seal but the dealer wants to know the number of the part because he's not shure of the part (cause it's too old he said)and i cant stay too long whitout my tractor( i do snow removal )i have a shop maual but nothing is explaned .i will do the job when i'll have the part and i have'nt seen a number on the seal...for now i fill the torque tube with oil and put the left wheel higher till i find the right seal number....Martn 42
LarryNeohiocase
12-07-2007 06:02:07
 Re: oil seal replacement for a 1969 430 case in reply to martin42, 12-06-2007 19:43:26
Martin,
Link
martin42
12-07-2007 14:58:04
 Re: oil seal replacement for a 1969 430 case in reply to LarryNeohiocase, 12-07-2007 06:02:07
thanks alot Larry, i think that"s it, it,s the right oil seal, i will order it as soon as possible.....Martin 42
