Restoration & Repair Tips Board
NAA - fuel shutoff valve
Dan (S.E. Mo)
10-22-2007 11:25:07
Sometimes, I do not use my NAA tractor for 3 or 4 weeks, so I shut off the fuel. Lately, the valve has become VERY tight, difficult to turn. I usually open it completely (many turns), due to problems with gas flow in the past. Is it necessary to always shut off/on, and if so, any ideas to loosen the valve so it is easier to operate?
old
10-22-2007 11:31:28
 Re: NAA - fuel shutoff valve in reply to Dan (S.E. Mo), 10-22-2007 11:25:07
Its always a good idea to shut off the gas to keep it from flowing into the carb if the float or needle doesn't seat as it should which does happen a lot of times. As far as how to make it turn easier if it has a nut that the valve goes through just loosen it a little bit and it should turn easier
Mashbox
12-16-2007 19:44:57
 Re: NAA - fuel shutoff valve in reply to old, 10-22-2007 11:31:28
You do not need to open the valve copletely. Only open it 2 turns. The valve is designed to give you a 1.5 gallon reserve, sort of like a reserve on a motorcycle. If you run out of fuel, open the valve completely, and you hopefully will have enough fuel to get back to the shed.
