Restoration & Repair Tips Board
tightening nuts and bolts
Flintlock
10-16-2007 13:12:54
Just split my 300U, new clutch and pressure plate.Removed the IPTO bearing cage, adding new bearings and seals. Also had head work done.And I am installing new front and rear crank seals.And took off the side plate to clean up the tappet area.But I can't find any torque specs for these nuts and bolts except the head nuts. Thanks Mike
CNKS
10-16-2007 13:59:32
 Re: tightening nuts and bolts in reply to Flintlock, 10-16-2007 13:12:54
Someone on the Farmall forum, this site, will know. However, the only critical ones are the crank/connecting rod bearings, if you did those. The side plate bolts, etc should just be snug, otherwise you will deform the gasket, causing leaks.
