Restoration & Repair Tips Board
steering wheel replacement
mwilke
10-06-2007 06:25:03
Can anyone tell me whether it is cheaper to buy a new steering wheel or have the rosin/rubber replaced? Is the quality of a replacement the same as the old one? And finally, where in the St. Louis area would I find a company that does the replacement?
Thanks
Mike
mwilke
10-07-2007 14:42:58
 Re: steering wheel replacement in reply to mwilke, 10-06-2007 06:25:03
Thanks for the replies. I have been seeing steering wheels on ebay. I suppose I will avoid those.
Mike
RustyFarmall
10-09-2007 12:59:59
 Re: steering wheel replacement in reply to mwilke, 10-07-2007 14:42:58
You have got to be careful about WHO you buy from on ebay. Some of those sellers do not have a clue as to what or how the part will fit because they have never used it themselves. I recently needed a new steering wheel for a Farmall H that I am working on, so I ordered one from my supplier and liked it well enough that I ordered more of them. Ebay is a good place to shop for tractor parts, but go directly to the ebay stores for the best bargains.
gab
10-06-2007 20:04:03
You can buy a replacement on Ebay but if you're even remotely fussy about what it looks like, you wont want it. I bought one, welded together crooked with big welds around the outside of the hub, looked worse than the one I was replacing. I sent it back. Jim
Gene Davis (GA)
10-06-2007 17:42:15
If you can find a suitable replacement on E-bay, then the replacement is usually cheaper. The look is not always original though. There is a company in Minnesota called Mine-Kota(sp?) that advertises they will rebuild any wheel.
JMS/MN
10-07-2007 14:05:30
 Re: steering wheel replacement in reply to Gene Davis (GA), 10-06-2007 17:42:15
Minn-Kota Repair is in Ortonville, MN. 320-839-3940. www.minnkotarepair.com.
