Restoration & Repair Tips Board
To Quiethorse
slowfolk
10-05-2007 05:42:57
Quiethorse
Have you been able to get the sleeves installed in your WD?
I just installed them in a WD and had no trouble. If you are thinking you have the wrong o-rings the ones I installed measure 1/8" cross-section. When cleaning the block bore for the sleeves there is a lead-in diameter that gets full of crap and appears to be part of the bore diameter. This crap needs to be cleaned out as this will assist the o-rings to lead-in to the o-ring sealing diameter. Apply plenty of dish soap to let the o-rings slip in easy. Haven't completely finished assembly of engine yet. Goodluck Slowfolk
