Restoration & Repair Tips Board
SuperC quit running
DWH
10-01-2007 00:30:54
Was using my 1951 SuperC friday.It was running great when it stopped all at once.No sputtering or anything.It wasnt under a load,and was only at half throttle.It wont crank back.Acts like its not getting fire.Any ideas or suggestions would be appreciated.
old
10-01-2007 06:48:07
 Re: SuperC quit running in reply to DWH, 10-01-2007 00:30:54
First couple things to check is does it have spark, does it get fuel to the carb. Then go from there. If it doesn't have spark try a hot wire from the battery to the coil. Does it have spark then if yes then your switch is bad or a wire broke. If it doesn't then the problem is from the coil forward.
