Restoration & Repair Tips Board
Three point hitch will not lower.
Lem Garner
09-27-2007 08:07:24
I have a 9N Ford tractor that the hydraulic 3-point hitch will not lower. The fork that goes down to the valve will not move when you put the handle down. I have checked the key and shaft that runs off the handle, it is okay. All the valve parts seem to be there and are operating, but the fork will not move it. I have cleaned the valves and pump, and put in new hydraulic fluid. When it pressurizes the top cylinder, the fork that is supposed to lower it to the valve will not move. Any suggestions would be greatly appreciated, thanks, Lem
Lanse
09-29-2007 17:06:35
 Re: Three point hitch will not lower. in reply to Lem Garner, 09-27-2007 08:07:24
This MAY help...
GunPilot
09-29-2007 22:27:15
 Re: Three point hitch will not lower. in reply to Lanse, 09-29-2007 17:06:35
Wow - this must be contagious third party image
soundguy
09-27-2007 11:57:30
Sounds like the valve is stuck. You may have to manually actuate it a few times.
Soundguy
36 coupe
09-30-2007 04:01:13
 Re: Three point hitch will not lower. in reply to soundguy, 09-27-2007 11:57:30
Dog bone valve is rusty and stuck.Happens to tractors that sit idle over winter.If the system is drained you can see if the dog bone is moving by looking thru the drain hole.The operating arms have springs on them and wont move a stuck valve.
soundguy
09-30-2007 07:18:53
 Re: Three point hitch will not lower. in reply to 36 coupe, 09-30-2007 04:01:13
He'd probably have more luck looking thru the inspec cover.. then he can manually try to actuate it and get a feel for how well it moves.. etc.. vs just looking at it..
Soundguy
