Restoration & Repair Tips Board
Z129 Continental Engine for TO30 Fergerson block repair
Philip VanderMe
09-18-2007 18:59:31
My block was cracked at the top and bottom between the liners. Filling the crankcase with coolant. I repaired it with out welding. I installed 3/8 bolts through the block between each cylinder at the top and bottom (6 bolts). I used JB weld in the cracks before tightening the bolts to seal them. Used JB weld in the liner bores by the cracks so the o-rings would seal. Has worked well, no more leaks, and made the block a lot stronger.
J Schwiebert
09-23-2007 18:15:23
 Re: Z129 Continental Engine for TO30 Fergerson block repair in reply to Philip VanderMeer, 09-18-2007 18:59:31
Somebody does or did make a kit for those blocks to do that. When I worked in my former job I ran into them. J.
paulsdiesel
09-18-2007 21:17:11
thats interesting. guy at the machine shop that i use told me about a z129 block that was brought in that was cross bolted on the bottom of cylinders; but i didn't see it. guess it had held good enough to build again.
