Restoration & Repair Tips Board
Radiator shutter on Farmall H
ryanvet
09-10-2007 06:05:28
I recently bought a Farmall H and just realized that I think it came with a radiator shutter. The lever is right above the on/off switch and goes down the right side to a lever at the oil fill. However, it does not move. There is a bracket at the on/off switch part of the lever that keeps it from doing anything. Anybody got an advice on this
glennster
09-11-2007 05:57:57
 Re: Radiator shutter on Farmall H in reply to ryanvet, 09-10-2007 06:05:28
take a peek thru the front grille and see if the shutter assembly is in front of the radiator. it looks like a set of metal window blinds. if the shutters are there, disconect the rod coming from the operators station at the bellcrank by the oil fill. then operate the bellcrank to see if the shutters are opening and closing. if not, they are gonna need some oiling and lubing. the shutters on my m had a small crank handle at the operator platform that turned in and out to open and close the shutters.
